Page 2 of 2 < 1 2
#368317 - 05/02/2017 16:24 Re: Big Disk Builder Error "Bad pump response" stage 0x25 w new ide Drive [Re: JeepBastard]
Hollywood Justin
Yes, indeed! Now I have the disk built but the riocar.org site is down, likely forever. I swore I saved the instructions for copying data from one drive to another but can't find them if I did. I know it's the dd command, but I don't remember the other details like which partitions need to be copied and if the drive with the music needs to be master before I start this process. Do you still have that knowledge or is there still a site that those FAQ's have been moved to that you know of?
#368320 - 05/02/2017 21:59 Re: Big Disk Builder Error "Bad pump response" stage 0x25 w new ide Drive [Re: JeepBastard]
Not the dd command. Instead, the filesystems should get mounted, and the contents of the /fid/ directories copied from one to the other.
One way is to connect the source and destination drives to a Linux box (or an empeg), then mount partition 4 from each of them (eg. /dev/hda4, /dev/hdb4), and copy the contents of the fids/ directory from source to destination.
#368321 - 06/02/2017 02:18 Re: Big Disk Builder Error "Bad pump response" stage 0x25 w new ide Drive [Re: mlord]
All right. I am totally stuck here without Tony's FAQ.
How does one apply a .upgrade file over serial from Linux?
Sorry I was out of touch when you needed me most! I don't know about .upgrade files, but the hex offset for kernel flash is memory location 10000. :-)
#368334 - 12/02/2017 21:10 Re: Big Disk Builder Error "Bad pump response" stage 0x25 w new ide Drive [Re: JeepBastard]
Hollywood Justin
I was also out of state on business, but thanks for your help Mark & Tony! Is there any chance that you guys could get a hold of the empeg FAQ's and host them on this site if riocar.org has been permanently decommissioned? That would be awesome since they do still occasionally come in handy.
#368335 - 13/02/2017 18:58 Re: Big Disk Builder Error "Bad pump response" stage 0x25 w new ide Drive [Re: Hollywood Justin]
The wayback machine works for the FAQ:
https://web.archive.org/web/20160322145524/http://www.riocar.org/modules.php?op=modload&name=FAQ&file=index
Unfortunately I can't seem to get the disk upgrade guide to work in the wayback machine. frown
#368336 - 13/02/2017 19:02 Re: Big Disk Builder Error "Bad pump response" stage 0x25 w new ide Drive [Re: tfabris]
Crap, no it doesn't. It doesn't have an index of the sub-pages. Sigh.
#368337 - 14/02/2017 01:02 Re: Big Disk Builder Error "Bad pump response" stage 0x25 w new ide Drive [Re: JeepBastard]
softspoken
#368338 - 14/02/2017 04:43 Re: Big Disk Builder Error "Bad pump response" stage 0x25 w new ide Drive [Re: JeepBastard]
#368341 - 15/02/2017 16:25 Re: Big Disk Builder Error "Bad pump response" stage 0x25 w new ide Drive [Re: larry818]
I don't think so -- that link describes how to re-do much of what the builder images have already done here.
#368346 - 16/02/2017 03:05 Re: Big Disk Builder Error "Bad pump response" stage 0x25 w new ide Drive [Re: JeepBastard]
Ok, it made mention of "big disks". Unfortunately the disk upgrade guide was external to the FAQ. I have the complete FAQ, (older that Soft's one above) which has dead links to the guide.
#368348 - 16/02/2017 05:28 Re: Big Disk Builder Error "Bad pump response" stage 0x25 w new ide Drive [Re: larry818]
Unzip to a special folder on your hard disk.
Double-click on "drive_faq.htm".
Disk Upgrade Guide.zip (43 downloads)
Page 2 of 2 < 1 2
